curious about headlights
Old May 1, 2011 | 06:06 PM
john doe's Avatar
Default curious about headlights
our 2002 sc2 has the typical condensation inside the headlights .i took them out 1 time and wiped them out with a reach tool and a rag .only to be disappointed the next morning when they were exactly the same way as befor .
question is
has anyone replaced theirs with new?
did the condensation problem stop with new ones?
or did the new ones do it as well?
i would hate to drop 150.00 on a set and have the same problem with new ones .
Old May 1, 2011 | 09:54 PM
I can't say it'll work for everyone, but I had the same problem on my ;98. Ultinately, I used a dremal tool and carefull drilled a #80 hole in the bottom of each of the plastic lens housings. The moisture collects in the bottom of thelens, andweeps out leaving s dry lamp lens ...
Old May 2, 2011 | 06:21 AM
john doe's Avatar
so yours dried up then ?
i thought about doing something like that .these lenses already have a weep hole with a small rubber fitting on it .but its located in the corner and apparently doesnt work very well.
my lenses dont pool up or anything ,just constantly have condensation inside which prohibits good lighting.
Old May 2, 2011 | 09:31 AM
Yes, mine dried up ...
Old May 2, 2011 | 01:32 PM
john doe's Avatar
so you drilled how many holes then ?
3?
like ,one in each separation?
Old May 2, 2011 | 05:27 PM
1 hole, at the lowest point, in each section
Old May 2, 2011 | 06:54 PM
john doe's Avatar
might have to try that .i hate seeing that condensation in there .what size is a #80 hole??i only have whatever bit came with my dremel and i havent loked at the size.
Old May 3, 2011 | 08:51 AM
(Sigh) -- a #80 drill equates to a diameter of 0.0135 in/0.343 mm
A1collins
Jan 19, 2015 07:20 AM
2008vueXE
Mar 28, 2014 10:53 AM
Jason Derfuss
Dec 5, 2011 01:56 PM
radar2k
Jun 7, 2009 11:00 AM
1995sc2DOHC
Dec 6, 2005 03:16 AM
