Bad thermostat?
Old Apr 21, 2011 | 09:06 PM
Epic's Avatar
Default Bad thermostat?
so i have a 02 sc2, the temp gauge never goes over a quarter of the way up but i still get heat. is this normal to be running that cool?
Old Apr 21, 2011 | 10:04 PM
likely a failed ECTS (Engine coolant temp sensor. tells the PCM the coolant temp and also drives the dash gauge. Influences air/fuel mix among other things. When they fail they tend to "read cold".
Replace with a brass tipped style replacement. Should also replace connector too.
Get from a GM dealer.
Two wire device located in cylinder head on passenger side. Use teflon tape on threads and work on a cool engine.
Old Apr 22, 2011 | 02:41 PM
Epic's Avatar
cool thanks, would have never guessed. would a autozone or one of those type places carry that or would that be something that is dealer only? since saturns are discontinued now
Old Apr 22, 2011 | 05:32 PM
connector is dealer only so might as well get the right ECTS while you're there
Old Apr 22, 2011 | 05:53 PM
Be sure to get a sensor that has a metal tip, not a resin-coated tip. Also, use Teflon tape on the threads.......
Carterx
Dec 13, 2010 12:13 PM
Jonnysig
Sep 16, 2009 07:25 PM
98sc2pcfl
Mar 13, 2009 09:25 PM
awesome_7
Mar 11, 2008 07:53 AM
Carrier999
Jan 20, 2008 09:53 PM
