Alternator Wires on ‘97 Sc2
Old Feb 3, 2025 | 12:22 PM
JayBird25's Avatar
Default Alternator Wires on ‘97 Sc2
Hey all, so recently I had to replace my alternator, and realized that the previous owner had a 2002 alternator, this of course does not work with the 97, and after replacing, I had found out that they have changed the plug and I need to rewire it. After getting the correct plug, it has four wires, while the old one only has two, is it suppose to have two, or do I need to find where the other two old wires are? Hopefully one of you might have an answer for me, I’d really rather not have to bring this into the shop. :/
Old Feb 3, 2025 | 01:50 PM
Only 2 of the four positions on the connector are populated.
B (F) goes to Brown/White
C (L) goes to Brown
S on the alt has no connection to the connector
Neither does the remaining terminal.
So only two wires to the connector.
The alt also has a separate ring terminal ground if I remember correctly.
See attached schematic snippet
Garden1977!
Jun 24, 2022 03:09 PM
Mera
Aug 22, 2011 09:09 PM
Kid831
Aug 12, 2010 06:51 PM
furbee86
Audio/Visual Electronics
Aug 1, 2008 10:16 AM
x0kalie
Aug 27, 2007 03:56 PM
