Turn signal switch won't cancel after turning
Old Aug 28, 2024 | 03:02 PM
MissVue138's Avatar
Default Turn signal switch won't cancel after turning
I just replaced my turn signal switch and now it doesn't turn off after you turn. So it did before replacing so I'm not sure what to do now.
Also, is it safe to drive it like that? It's my only vehicle but I don't want to run the risk of an electrical short while driving. Not sure what to do now. As I took it back apart to look at it and put it back together to find the same issue. I noticed that the new one doesn't fit as snugly as the old one. Not sure if that matters or not. I'm new at this
Old Aug 28, 2024 | 03:44 PM
Only vehicle......
If we only knew what it was......
Old Aug 28, 2024 | 06:57 PM
I have had the replacement t/s switches not cancel properly. The VUE and the L series cars use the same switch. Not cancelling will not cause you a problem with your car. It will be extremely irritating to other drivers if your blinker stays on. The switch probably does not fit properly, another switch might work perfectly or it may be the same.
Selcat
12
Aug 16, 2024 07:59 AM
IonProblems3v3ryDay24/7
May 23, 2018 10:04 PM
ford88mustang
Nov 15, 2009 07:17 AM
sts9
Nov 5, 2007 10:00 AM
flyjetguy
Sep 21, 2007 11:24 PM
