timing help
Old Jul 12, 2010 | 09:11 AM
BMarsh's Avatar
Default timing help
How do you set the timing on a 99 saturn dohc
Old Jul 12, 2010 | 03:37 PM
hoseppi's Avatar
Why are you trying to set the timing? I think you have other problems. The timing is not manually adjustable like it used to be on distributor type engines.
Old Jul 12, 2010 | 05:41 PM
yeah unless you are in the middle of a rebuild
Old Jul 12, 2010 | 11:35 PM
BMarsh's Avatar
im rebuilding the head on it and was wondering how to set the timing on it once i get the head all put back together.
Old Jul 13, 2010 | 08:35 AM
hoseppi's Avatar
Ok, you mean the cam timing.I thought you meant ignition timing to diminish a spark knock or other engine noises. If you are reinstalling the original chain, gears,guides and tensioner, the Haynes manual provides adequate instruction. If it is a new set,it should come with manufacturer specific instructions, or check the Richpin series on You Tube. I just checked and there is no Richpin video on timing chain installation
Old Jul 13, 2010 | 09:54 AM
Haynes, Chilton, Mitchel
in general available at auto parts stores nation wide.
winkler91
Oct 21, 2012 07:38 AM
richard drone
Feb 21, 2010 09:31 AM
mtsumedi
Sep 22, 2005 07:36 PM
B3SL1
Aug 4, 2005 09:49 AM
RonRon
Apr 5, 2005 02:57 AM
