Replacing Engine with Salvage Engine
Old Sep 11, 2008 | 09:59 PM
jghoppes's Avatar
Hello,
Ihave a 2001 Saturn SL2 that I am replacing the engine in with a 64,000 salvage engine. I was wondering if and what I should replace on it. The maintenance schedule only shows the normal stuff. Should I replace the timing chain or other hard to get to parts while the engine is out?
thanks
Josh
Old Sep 13, 2008 | 03:51 PM
jisnut's Avatar
It would probably be a good idea to check that kind of stuff. Check cylinder pressure the timing belt ect. I would replace gaskets too. Just to be on the safe side.Edited by: jisnut
Old Sep 15, 2008 | 11:43 AM
jghoppes's Avatar
Which gaskets would you replace? The compression is 200+ in each cylinder.
thanks
Josh
Old Sep 15, 2008 | 11:51 AM
TheEngineer's Avatar
I would just replace all the usual stuff like the exhause and intake manifold gaskets, the valve cover gasket. And as always, anything that has a gasket you remove you should replace it. As far as anything internal, you shouldnt really need to replace anything as far as seals go
Old Sep 15, 2008 | 03:30 PM
jisnut's Avatar
yeah just intake, exhaust, i might even do the head gasket, along with the valve cover.
Old Sep 15, 2008 | 05:21 PM
jghoppes's Avatar
Thanks for all your advice. I hope to have the engine in this weekend!
Josh
E04677
Nov 22, 2009 09:32 PM
aikensaturn
Nov 4, 2009 06:39 AM
moriad02
Oct 10, 2007 08:07 PM
Ryan
Sep 20, 2007 05:36 PM
mikesta
Jun 11, 2007 04:54 PM
