Cracked intake & turbo
Old 07-07-2016, 11:29 AM
kenbigdaddy's Avatar
Default Cracked intake & turbo
I took my 2008 redline in yesterday for a new water pump. The tech had to remove the intake and turbo and when he did, discovered a fairly significant crack in both. I was wondering if anyone else had a similar experience. It's about a 3 grand repair.
thanks
Ken
Old 07-07-2016, 09:59 PM
Ken_Phill,
There is a GM bulletin which discusses
Turbocharger Housing Inlet Flange Cracks in Partition Wall
It is Manufacturer Communication No.: SB-09-06-93-002
See below
Subject: Turbocharger Housing Inlet Flange Cracks in Partition Wall
Models: 2008-2009 Chevrolet Cobalt SS, HHR SS
2007-2009 Pontiac Solstice GXP
2007-2009 Saturn SKY Redline
2007-2009 Opel GT
2007-2009 Daewoo G2X
All Equipped with Engine RPO LNF
Important: DO NOT replace the turbocharger assembly for this concern.
The purpose of this bulletin is to address concerns with turbocharger housing cracks in the inlet flange partition wall.
The pictures below illustrate typical cracks found in the turbocharger housing.
SORRY NO PICTURES
This illustration shows the location of the cracks in the partition wall of the turbocharger inlet flange on the left (1) and on the right (2).
This illustration shows a close-up of the crack on the left side of the partition wall (1).
This illustration shows a close-up of the crack on the right side of the partition wall (2).
These cracks are not uncommon and are considered a normal condition and should NOT be a reason for replacing the turbocharger assembly. The cracks will not affect performance.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
As stated above, certain cracks in the turbo housing are "not uncommon".
Well that's good to know that everyone else has QC problems with the same part. I wonder when they DO become significant. Thermal expansion and contraction are problems overcome by design. But extra material in the turbo and ex mani= extra $$ in production costs. And as we all know, the sticker price rules.
Also, depending on the location of the cracks, it may not require replacement (turbo).
jamnar
10-21-2015 12:51 PM
02satcrashed
02-12-2011 01:31 AM
nonis
06-17-2009 05:20 AM
herkrider
01-22-2008 08:11 PM
betinaq
06-13-2005 10:19 AM
Quick Reply: Cracked intake & turbo
