Chem Dip Piston Soak
Old 05-07-2013, 01:13 PM
nrraiders35's Avatar
Default Chem Dip Piston Soak
I have a real oil burning problem in my 1997 saturn sl and was considering doing a piston soak with berryman's chem dip. I know it is a ring problem and can see carbon build up on the piston head with the sparkplugs removed. Just looking for some opinions.
Old 05-07-2013, 02:14 PM
Well give it a try.
Have a new set of NKG plugs and fresh oil once your all done with the soak along with running the car and the smoke has cleared..
Old 05-08-2013, 07:34 AM
I agree with SW2CAM. Nothing ventured, nothing gained. But, you do know you can only soak two pistons at a time, right?
Old 05-10-2013, 07:46 AM
i always thought they all moved up and down together
Old 05-10-2013, 08:17 AM
Crank is offset where two pistons will be up while the other two are down. Gotta have a 180 degree turn to soak the other two. I THINK 1 and 4 are up while 2 and 3 are down and then vice versa. Someone tell me if I'm wrong on this, please.
Old 05-13-2013, 07:46 AM
Well, nothing ventured nothing gained is the root marketing concept of the success of snake oil to cure the incurable as a miracle elixir. Not sure how you are supposed to use the stuff (but I'd bet a 2 liter bottle of Coca-Cola would be about as affective) but if it depends on he cylinder bore to be a container of the stuff, half a turn puts the pistons (all of them) half way down giving half a cylinder bore as a container to fill up. Just remember to change the oil before you start or try to start the engine. Or didn't the instructions mention that?
winkler91
09-09-2012 08:59 PM
niki02girl
11-04-2010 08:56 AM
97 SL2
06-30-2008 05:50 PM
paulorlo
11-03-2006 01:00 AM
Quick Reply: Chem Dip Piston Soak
