Broken rocker arms help?
Old Apr 25, 2012 | 07:57 PM
Richard Weed's Avatar
Default Broken rocker arms help?
I'm in the process of picking up a 1995 coupe with engine issues. It's a single oveer head cam motor. Problem is 2 intake rocker arm are broke? Not sure why. Is this an common issue with this motor? I went to the wrecking yard for parts and found other motor with the same broken arms. I think the previous driver ran with out oil? I put 2 good arms on and now it looks like the intake valves are open because there is to much lash. have not spun moror over yet thats tonight.
any help, insight, or suggestions are welcome.
Old Apr 25, 2012 | 09:24 PM
No it's not a common problem with the 1.9L sohc or dohc. Get the book and find out how to install the rocker arms.
Old Apr 25, 2012 | 11:07 PM
i'd be wary if it were me but sounds like it's too late
Old Apr 25, 2012 | 11:17 PM
Yep, it sounds like the pistons have already punched the valves. Replacing head is in order.
Old Apr 26, 2012 | 01:06 AM
for this to happen the timing would hqve to jump. The motor has a timing chain not belt. could the timing jump chain sprockets?
I was thinking the motor got hot and seized the valves in guides or the lifter need to pump up? I'm pulling at straws. compression test is next.
Old Apr 26, 2012 | 08:49 AM
Yes if the chain is worn then the slack could be enough for it to jump just as it could in a bigblock prostreet 454. You put replacement rockers on and they are loose to the valves? Does that not sound like the valves are open? If they are open why? Valve springs broken? Valves bent? Pull the head and find out whats going on.
Old Apr 26, 2012 | 12:24 PM
I have to wonder what happen when the rockers broke ..... I can see it as being a little invasive to other parts of the valvetrain.
Vic Flange
Jun 10, 2015 10:59 PM
richard drone
Feb 21, 2010 09:31 AM
winter beater
Dec 14, 2006 11:59 AM
rafferty
May 18, 2006 01:48 AM
instil
Aug 18, 2005 12:26 PM
