2008 Astra Door Locks
Old Apr 21, 2020 | 10:35 AM
GregoryD's Avatar
Default 2008 Astra Door Locks
Hello there. I'm new here. Our daughter has a 2008 Astra. The rear driver side door lock stopped functioning ( the other 3 locks work fine ) so they bought a replacement only to find that the old actuator does actually work. I had suggested electrical troubleshooting before buying parts but, hey, I'm just dad. So today I took the fuse out of the rear fuse panel to test it and it's fine. However, upon replacing said fuse, now none of the locks work. So the deal is, only one lock was malfunctioning, checked the fuse and now no locks functioning. Retest fuse and still nothing. Anyone know anything? GM dealers in our area are pompous asses who hear 2008 and I'm doing it myself and lose interest immediately. Any help would be greatly appreciated.
Thank you
Greg
P.S. The only lock functioning now is the rear hatch lock.
Old Apr 21, 2020 | 06:05 PM
Remove the fuse and measure the resistance of the fuse on the ohms setting while the fuse is out.
Inf resistance as you know means blown. I'm guessing you did a visual check and not a measurement.
The fuse prob popped when you put it back in. So it WAS good before then, popped, and now requires replacement.
Let us know
Old Apr 22, 2020 | 11:53 AM
GregoryD's Avatar
Hi derf. I popped the - btty terminal off and it reset back to what it was. When it get's back up above zero Canadian, I'll check the harness at the pillar. Seems others have had this problem - as well as speakers - before. Apparently the wires can weaken at that point and fail. Thank you.
Old Sep 2, 2024 | 06:36 PM
isaacjh's Avatar
Default Same problem
Thank you
Greg
hello Greg! I am having the exact same issue. How did you resolve this?
Old Sep 2, 2024 | 07:14 PM
I doubt you will get a response other than this one.
Old Sep 3, 2024 | 09:41 AM
4 yr old
Old Sep 7, 2024 | 12:44 PM
GregoryD's Avatar
Hi there,
I tracked the problem to a suspected broken wire in the loom that runs between the pillar and the door. I didn't fix the problem as our daughter is impatient and has just had to live with it. But that's where the problem is.
Cheers
Greg
Old Sep 7, 2024 | 01:06 PM
grcauto8453's Avatar
The wiring in the loom gets exercised a lot. I've seen a few where several wires were bare of insulation in spots. Shorts happen but more are opens.
Haxxbot1208
Feb 6, 2024 08:08 PM
PaulWR
Saturn Astra
20
Apr 27, 2015 09:46 AM
DailyPlanet
Jun 29, 2014 07:24 PM
tealsc1
May 17, 2010 04:04 PM
MINICooperS
Sep 6, 2009 12:22 PM
