1996 Saturn SL
Old 06-19-2014, 09:04 PM
Chris77's Avatar
Default 1996 Saturn SL
Brake light warning on dashboard is lit up. The brakes don't make any squeaking noises, doesn't feel weird and there is no warning sound/beeps. Do I just need to add brake fluid (and if so what kind?). . . . or do I need to take my car to a repair shop? I am the origianl owner of this car since 1996 and have taken very good care of it so I am at a loss on what to do. Being a female I am hesitant to just take to a repair shop because all they see is a dumb clueless woman with dollar signs in Their Eyes! Oiy-vay! Truth.
Old 06-19-2014, 09:08 PM
Guess it's time to start learning. Open the hood and look, if it's low on fluid add some. What kind of brake fluid you ask, it says right on the cap. If you have the owners manual, read it.
Old 06-19-2014, 09:13 PM
Chris77's Avatar
Default thank you
okee dokee. just asking but thank you for your quick and kind answer
Old 06-19-2014, 10:30 PM
DOT 3 brake fluid. You can get it at your local Walmart. No need to go to an auto parts store and pay twice the price. If you have a boyfriend or husband or brother that doesn't mind looking under the car, have him look at the back side of each tire and see if there's any fluid on it. If so, you may have a leak, if not, then probably just need to add some fluid.
Old 06-20-2014, 08:14 AM
Chris77's Avatar
Default Thank you!!!
I have absolutely no one, no one to help me at all. That is why I am reaching out to people on this site. But I will check it out like you said. Thank you so much <3
Old 06-20-2014, 06:48 PM
You are welcome. Please post back and let us know if that's all you needed or you need more help.
Old 06-20-2014, 10:52 PM
not at all trying to be insulting but are you sure the emergency brake lever is all the way down (nothing blocking its travel.}?
I've occasionally gotten stuff wedged under there and if the lever is not completely down the brake warning light will stay on.
Old 06-21-2014, 06:54 AM
Chris77's Avatar
Default Thank you :).....
most definitely checked out the emergency brake first thing and i was not insulted that you mentioned that at all I had to get my oil changed anyway so the oil change place said the brake fluid was just a teeny bit low and that means my brakes are using more fluid because the brakes need repair, etc., they checked my front brakes (they were fine) and the back brakes are drums (so a visual check was not possible) so after the oil change and a teeny dab of brake fluid the light has not come back on. They said sometimes? the wire thingy attached to brake light stuff (sorry, not very techy but I got the jist) might get a little loose and make the light come on? I will keep an eye on it for sure. I truly appreciate all the responses I have gotten, really I do Thank you!
Old 06-21-2014, 08:02 AM
All righty then! Another satisfied new member, for now!
Uncle Phil
02-05-2008 07:04 PM
2slow4u
01-13-2008 12:12 PM
NvMySi
10-09-2007 03:13 PM
jumpshotjonny
04-11-2007 10:07 PM
waldowarlord
04-13-2006 03:54 AM
Quick Reply: 1996 Saturn SL
