1994 SL2 auto trans slipping
Old 06-26-2016, 06:03 PM
ElusiveDream's Avatar
Default 1994 SL2 auto trans slipping
Car is old and has lots of miles, 378k
I changed the valve cover as it was leaking and after putting it back together took it for a drive and the transmission started slipping.
Never had an issue prior to the valve cover repair.
Changed the fluid and filter ran smooth for a few miles then started slipping again.
Is there anything that taking off the valve cover would have done to cause this? Something i missed hooking back up maybe?
Sorry not the biggest car person in the world.
Thanks
Old 06-26-2016, 09:03 PM
At 378K, if that is the original AT in the car, you're about 200k mi overdue for AT tranny slippage.
On these ATs the input shaft nut works its way loose and the valvebodies become problematic.
The fact that you are OBD I sucks unless you have a scan tool that can read the TCM in the car
Is the SES light on?
Old 06-26-2016, 09:05 PM
Re check to make sure all vacuum lines are reconnected
Old 06-26-2016, 09:07 PM
No lights on, original drivetrain. I bought the car for $600 at 196k and have only put a water pump and brakes on the thing.
Have read some of the valve body issues in here, was just curious since it started immediately after swapping out the valve cover if I just missed something on reassembly as it ran perfect when i took it apart.
Old 06-27-2016, 01:46 AM
i will pop my hood in the morning and see what's where and post back
dkriz
03-16-2018 12:31 AM
junior
12-02-2009 06:34 AM
Stefi
08-02-2008 09:52 AM
HOTROD1935
05-02-2007 02:34 PM
iw433
03-24-2005 08:23 PM
Quick Reply: 1994 SL2 auto trans slipping
