@2002-2003 l200 Shift indicator lights wiring diagram
Old Sep 10, 2018 | 11:28 AM
thebiglar's Avatar
Default @2002-2003 l200 Shift indicator lights wiring diagram
Would anyone have the wiring diagram for the shift indicator lights PRND123 on a L200 automatic console shifter. There are 8 wires on the plug that plugs into the light module. I am assuming that one is a ground and the other 7 go to each shift indicator light. I have tested wires with a meter for continunity but can not seem to figure out which is which is which. I am trying to use this in a console on a street rod I am building. Any help is appreciated.
Attached Thumbnails @2002-2003 l200 Shift indicator lights wiring diagram-img_3444.jpg   @2002-2003 l200 Shift indicator lights wiring diagram-img_3446.jpg   @2002-2003 l200 Shift indicator lights wiring diagram-img_3445.jpg
Old Sep 11, 2018 | 10:45 PM
I’m working on this for you
Attached Thumbnails @2002-2003 l200 Shift indicator lights wiring diagram-f3292b93-afaa-4aa3-b626-ae66d7997512.jpeg
Old Sep 11, 2018 | 11:47 PM
It is actually a module and I would really have to want to know how it works to spend more time. I would power it, ground it and power the lighting and play with the other 4 one at a time and see what lights up.
Attached Thumbnails @2002-2003 l200 Shift indicator lights wiring diagram-92d3f0ea-7b46-4ad8-a7b2-8e671a8f878a.jpeg   @2002-2003 l200 Shift indicator lights wiring diagram-15fdf5de-95e3-4698-bde2-9dad31fe1dd1.jpeg
Old Sep 12, 2018 | 08:25 AM
thebiglar's Avatar
Default Very Helpful
This helps a lot. By what I see here the black wire is the ground for the module and the other 7 wires would go to each of the 7 indicator lights. So if I use a battery charger as power source and ground the black wire each light should light up as I touch them to power. I have a sender that will hook to the trans linkage and will power each light as gear is selected, so I have that side covered to get power to the lights when this is finished. Just have to get the lights working. I will do some more testing and let you know how I make out. Thank you very much.
Kasper_B
May 22, 2019 01:14 PM
mikenic
Jun 24, 2018 09:23 PM
saturns_moon
Jan 24, 2014 11:20 AM
cliffsongs
Jan 13, 2012 06:53 AM
LmyVue
Oct 9, 2008 10:23 AM
