1994 sl2
Old Sep 10, 2009 | 07:30 AM
  #71
The hardest thing to diagnose "from afar", are loose connections and phantom problems. Good luck.....
Old Sep 10, 2009 | 09:33 PM
  #72
so EGR solenoid was the only thing causing code 26?
Also -- what happened with the A/C?
Old Sep 11, 2009 | 06:21 AM
  #73
paulsl2's Avatar
I never went to the saturn dealership it is on the other side of the state , I dont know why or how the check light just stopped comming on, it is still giving me a code 26 , but no light an it is not burned out when i start the car I can see the light
Old Sep 11, 2009 | 07:47 AM
  #74
I'm thnking it should clear itself after enough drive cycles.
Either that or it is the ODB I equivalent of a "pending" code, and the light will eventually come back on.
Time will tell.
Old Sep 11, 2009 | 01:56 PM
  #75
paulsl2's Avatar
I was reading in the chiltons book it said after 50 starts it will recycle it self and go back to code 12 Imust be getting close?!
Old Sep 11, 2009 | 06:48 PM
  #76
Couldn't tell ya -- you never drive me anywhere
Old Sep 12, 2009 | 09:34 AM
  #77
paulsl2's Avatar
ha ha
Old Sep 16, 2009 | 12:56 PM
  #78
paulsl2's Avatar
It finely pasted 50 start cycles an it"s reading a code 12! I"m not going to f... With it ,hopfuly it will stay at12 without any wornning lights.
Old Sep 16, 2009 | 06:40 PM
  #79
well then, egr solenoid was apparently the culprit.
Happy code 12 ing
Old Sep 16, 2009 | 07:24 PM
  #80
after 81 posts and finally no codes other than a 12.....
you're welcome.
