Saturn SL2 thermostat replacement
Old 12-12-2010, 01:26 PM
Carterx's Avatar
Default Saturn SL2 thermostat replacement
I've been looking around online to see if replacing the thermostat is something I can do. Is this a complex job? Some sites say you need to drain the rad & some say no. Not sure if this is something I can do or should be a shop only job?
Thanks!!
Old 12-12-2010, 01:51 PM
Drain the radiator and you can reuse the coolant if it's reusable. Don't drain the radiator into a container and what ever comes out goes all over the surface your working on. I'm not sure if this is a job you can do or not. I have no idea what your capable of doing or what tools you have to do the job.
Old 12-12-2010, 05:35 PM
Carterx's Avatar
so after talking to a few people they think it's not the thermostat since the dash temp gauge still works. What else might cause the car to get no heat? The blower is fine and the temp gauge works.
Old 12-12-2010, 05:58 PM
Low coolant leval or maybe needs a good power flush.
Old 12-12-2010, 11:59 PM
Or
the controls for the heater are defective or the heater core is disconnected
or a bit more information might be helpful.
Such as
o.k., so the gauge works, was that what you were trying to determine in the first place? Can you feel heat in various hoses? the bigger ones that go from the engine to the radiator? the smaller ones that go to the heater?
What happens when you move the heat control lever?
If you are looling for heat to come out anywhere how about does it come through the defrosters?
Does the car have A/C?, Does it work?
Old 12-13-2010, 12:13 PM
Yes - also, the year and the model of your Saturn would be a big help as well.
AjayIV
12-12-2013 11:40 AM
john doe
08-29-2013 02:58 PM
98sc2pcfl
03-13-2009 09:25 PM
awesome_7
03-11-2008 07:53 AM
Carrier999
01-20-2008 09:53 PM
Quick Reply: Saturn SL2 thermostat replacement
