Suspension Talk about your suspension within...
lower control arm/balljoint repair
Old May 27, 2010 | 10:19 PM
DarkDave's Avatar
Default lower control arm/balljoint repair
How much should i expect to spend.... from what i can find its about a hundred bucks per side?
big job? any tricks?
Old May 28, 2010 | 03:44 PM
richpin has a video on youtube follow at own risk
I just did one on my 97 Sc2 a few weeks back -- "tricks" are in the video
recommend the pricey dealer part -- the sway bar bushings on the cheaper ones are purported to trash easily
otherwise I've read moog works well
Old May 30, 2010 | 11:22 AM
DarkDave's Avatar
nice. i had found that vid as well, im gonna give it a go on my own i even have a come-along handy to use.
Im using cheap parts tho lol cheap is the idea, hence the reason i didnt spend over $500 on the thing!
Old May 30, 2010 | 10:18 PM
36 in crowbar 30 is not quite long enough
Old May 31, 2010 | 12:01 AM
The video URL is;
http://www.youtube.com/watch?v=5PjkfDp8mLE
and
a handy crow bar extension tool is to use a large box end wrench. One with a big enough nut size so that the crow bar fits through the hole for the nut slopply and it can add an extra foot or so to the length of the crowbar.
If you don't have a come-along and there is a Harbor Freight store available, they can be purchased their along with a logging chain fairly cheap and some times it takes a certain hammer to successfully pop a ball joint in the manner described. If this is not so working invest in a "Pickle Fork" which will. They come in different sizes, larger for ball joints and equivelent, smaller for steering arms and Tie Rod ends.
Old Jun 1, 2010 | 12:40 AM
DarkDave's Avatar
sweet. im liking this forum already
luckily, i used to work at a tool/equipment rental place and still have a good relationsip with the owner. i can get ahold of a picklefork set if the 'peen doesnt pop it out
Old Jun 1, 2010 | 05:42 PM
if you get some downforce on the control arm while whackin the knuckle it should release
Tatted up ion
Jan 1, 2014 08:52 AM
Merkle85
SF Help & Suggestion Center
Jul 4, 2013 08:48 PM
SeanSL
Apr 25, 2012 07:11 PM
DStanbury
May 19, 2010 08:51 AM
leftys4js
Aug 12, 2008 09:06 AM
