Winter Tires.... Will they fit?????
Old Oct 24, 2008 | 11:20 PM
rinskimike's Avatar
Will P235 / 65 17 winter tires be ok on my 06 Vue? The original tires are 235 / 60 17''s. Thanks
Old Oct 25, 2008 | 06:25 AM
OK - Here are the figures:
Existing tire 235/60/17 - assembled diameter of tire 28.10 in; tire circumfrence is 88.28 in.
Winter tire P235/65/17 - assembled diameter of tire 29.02 in; tire circumfrence is 91.19 in.
This will result in an increase in speed of 3.2 percent from stock conditions. For example, at 100 kph shown on the speedometer, you will actually be travelling at 103.2 kph.
Will that additional inch cause a problem with body/wheelwell clearance? Probably not, but I would check out carefullywith hard right and left turns at slow speeds in a flat parking lot somewhere and listenfor sounds of rubbing/binding before I took it anywhere at normal speeds ...
skooter
Jun 18, 2020 07:06 AM
Rubehayseed
Oct 25, 2013 09:56 AM
GloŽbz
Nov 3, 2010 07:13 PM
autobahn70
Tires
Oct 1, 2009 09:51 PM
the4ork
Aug 31, 2007 07:18 PM
