Swapping 2.2 for 3.5
Old Mar 29, 2021 | 08:52 PM
DevilDawg's Avatar
Question Swapping 2.2 for 3.5
Hey guys,
I have a 2004 Saturn Vue AWD that has a 2.2. I have located a 2006 AWD Vue with a 3.5. I would like to swap them but not too sure if the two are completely compatible and what issues I may run in to. If you all have had experience or even a link to a break down. I am pretty sure I will have to swap the ECM, PCM and the like. I would just use the 2006 but it has major rust issues and not safe
Old Mar 29, 2021 | 09:26 PM
Off the top of my head you may also need to flash the BCM to match the options on the 2.2.
Obv difference in exhaust setup will require some reconfig. I would postulate that the exhaust flow of a v6 may not be happy though the system a 2.2.
If you take the engine, save yourself a bunch of trouble and bring the transmission along. I believe it is different from the 2.2 transmission, plus you will already have the correct TCM.
No clue about the rest.
Old Mar 29, 2021 | 09:30 PM
That would be like swapping an L200 into a L300. The steel is the same but every wire and mechanical piece is different. Way more work than it is worth unless you don’t have a job.
Old Mar 30, 2021 | 09:09 AM
You'd best listen to Andy. That man knows his stuff !!
Old Mar 31, 2021 | 10:38 PM
DropDead's Avatar
Where you located? I could probably help supply parts for pretty cheap
Old Apr 1, 2021 | 09:38 AM
Hey Devil Dawg, I see you're in Paris. I used to live in New Johnsonville. Had a buddy named Johnny Boyson that lived in Paris. Do you know him? Can't trust him with a dollar!!!!
Michael Bond
Jan 17, 2021 08:05 AM
Brandonwidener22
May 1, 2020 07:15 AM
CephEsaul
Jan 6, 2020 04:43 PM
jmerk
Apr 28, 2019 04:44 PM
ob1coby
Nov 19, 2018 03:19 PM
