Stereo questions
Old Aug 26, 2025 | 06:28 PM
Vndin's Avatar
Default Stereo questions
hey guys, i installed a aftermarket android tablet head unit in my 2004 vue redline and was wondering what adapters etc you need to get to continue using the factory sub.
The factory cd/dvd player has 2 connectors, one which is the speaker etc harness which is normal and then it has a smaller black connector that also plugs into the factory head unit...
i figured thats the sub power etc bc when i put the factory head unit back in and hook both harness into it the sub works.
Ive had NO luck what so ever finding the right harness adapter. I would even consider cutting the factory harness etc if i could find the pin outs and what does what on that harness so i could wire it in w the aftermarket radio to still use the sub.
any help would be greatly appreciated. I really want to use the factory sub and box without having to run a new amp etc.
Old Aug 26, 2025 | 06:46 PM
oldmarine's Avatar
Check this wiring diagram from charm.li. Radio wiring diagram for RPO code U2K
Go down to Diagram 3. It shows two connectors, the one on the left has 4 wires that go to the subs. If this is the wrong diagram, backtrack and find the correct RPO code.
Vndin
Aug 17, 2025 11:02 PM
MTN DU
Saturn Aura
Jan 3, 2019 03:30 PM
chargernut
Apr 4, 2013 08:19 AM
RedRocket
Jun 18, 2010 01:00 PM
hartman
Audio/Visual Electronics
Mar 27, 2007 04:21 PM
