Stalling
If someone changed my clutch, I'd think they would put a new master/slave unit on it, but then again, many people do not think as I do. As long as they did not drive the piston out of the bore and wreck the slave seal, it shouldn't need bleeding.
Is the service engine soon light on?
Does it stall in neutral when rolling up to a light?
Will it stall in low gear rolling up to a light?
On a flat surface, if you start the car and put it in neutral w the emergency brake off, does the car try to move? If you then depress the clutch all the way and put it in first gear, does the car try to move with the clutch pedal to the floor?
