Stalling
Old Oct 18, 2016 | 02:21 PM
1991kahuna's Avatar
Default Stalling
2005 Saturn Vue, 2.2 4 litre 5 speed manual trans, just had clutch changed and now car will stall intermittently at stop lights or whenever we stop. Never did this before clutch was changed
Old Oct 18, 2016 | 08:06 PM
You may have to clear the codes so it can relearn how it idle. I don't know if this is what you need for sure but it fixes the Fords at work.
Old Oct 19, 2016 | 07:08 AM
Maybe check the fluid in both the master and slave cylinders? Did you bleed the system?
Old Oct 23, 2016 | 01:49 AM
If someone changed my clutch, I'd think they would put a new master/slave unit on it, but then again, many people do not think as I do. As long as they did not drive the piston out of the bore and wreck the slave seal, it shouldn't need bleeding.
Is the service engine soon light on?
Does it stall in neutral when rolling up to a light?
Will it stall in low gear rolling up to a light?
On a flat surface, if you start the car and put it in neutral w the emergency brake off, does the car try to move? If you then depress the clutch all the way and put it in first gear, does the car try to move with the clutch pedal to the floor?
sdward
Apr 29, 2006 12:11 AM
jillowolf
Jan 14, 2006 08:51 AM
Erinb2626
Oct 4, 2005 04:41 AM
Erinb2626
May 25, 2005 09:19 PM
Terry
Mar 28, 2005 11:34 PM
