Saturn vue ac problem
Old Jul 9, 2018 | 11:09 AM
Wtlostu's Avatar
Default Saturn vue ac problem
picked up a Saturn vue with the 3.0..ac isn't working compressor isn't running. There's a pressure switch in the line coming off the compressor running to the condenser. All the wires are broke can't find the opposite end any help on where to look?
Old Jul 9, 2018 | 02:58 PM
People often do stuff like that when a system is damaged to the point of being dangerous and they do not want to be liable when they sell the vehicle.
People also do stuff like that when they are clueless.
Please include the year.
Old Jul 9, 2018 | 05:22 PM
Wtlostu's Avatar
My bad it's an 03 with the 3.0. And I don't think they disabled it. If that was the case why not pull the and relay? Guy hit a deer in it and t think the fan caught the wire it's not a clean cut
Old Jul 9, 2018 | 07:05 PM
Thank you for the additional information. Would never know a collision was in play otherwise.
What all sustained damage and what has been repaired? It may sound like an off topic question, but if the wiring for the cutoff switch got pushed back into the fan blade, you should consider what else may have been damaged besides the air conditioning wiring
Old Jul 9, 2018 | 08:16 PM
Wtlostu's Avatar
Pretty much just a hole in the radiator. I fixed that and put headlights in it the condenser and the transmission cooler are bent but looking ok, the plastic bumper is beat up but it'll work. By the way I paid 300 for it and had it on the road same day
Old Jul 10, 2018 | 04:43 PM
The L series cars have a three wire switch in the high side pipe. It is not as simple as the S cars were in the 90s. When I get back to Oregon I can take some pictures of a 3.0 in an L series the wiring should be close.
Old Jul 10, 2018 | 10:54 PM
Thanks, Andy.
I deleted my post above Andy's to reduce confusion.
Old Jul 11, 2018 | 01:02 PM
Wtlostu's Avatar
Ok. Got it wired up, what's the best way to jump the compressor on this? It's not coming on by itself I'd like to see that the clutch is good before I vacuum the system and refill it
Old Jul 11, 2018 | 03:26 PM
I jump them at the clutch to listen to the compressor. Otherwise there has to be pressure before the system will turn it on.
JosephJ80
May 28, 2023 11:33 AM
dotman
Mar 5, 2022 08:06 AM
sadatt
Oct 10, 2018 03:55 PM
oifish
May 7, 2013 08:40 PM
jimbob
Jul 26, 2006 01:17 PM
