01 L sedan AC problem
Old Jul 26, 2018 | 01:38 PM
dotman's Avatar
Default 01 L sedan AC problem
i cant get the compressor to spin.it has a 3 wire connector to the pressure switch.i only get 5.7v to this switch. is this normal?
Old Jul 26, 2018 | 11:44 PM
Please don’t mess with that switch. It is controlled by a computer somewhere in the car. There is a detailed troubleshooting process in the FSM on the a/c system.
Let’s start here!
Does the light on the switch turn on when pushed? The fan has to be on for that button to light up. I have low pressure not engage the clutch and I have also had a bad clutch coil cause a problem. This year I had to replace my compressor, the system was charged and the clutch engaged just no flow from the compressor.
Old Mar 5, 2022 | 08:06 AM
You might try these guys.
GM 21030824 Switch, genuine OEM part Or these. https://www.wholesalegmpartsonline.c.../21030824.html
And now I'M done too.
Dtruck1
Sep 8, 2013 10:34 PM
major
Jun 12, 2010 12:09 PM
bucky katt
Aug 16, 2009 11:45 PM
snellenj
Jul 17, 2009 07:39 AM
Steve76
Jun 3, 2008 05:58 PM
