01 L sedan AC problem
i cant get the compressor to spin.it has a 3 wire connector to the pressure switch.i only get 5.7v to this switch. is this normal?
Please don’t mess with that switch. It is controlled by a computer somewhere in the car. There is a detailed troubleshooting process in the FSM on the a/c system. Let’s start here! Does the light on the switch turn on when pushed? The fan has to be on for that button to light up. I have low pressure not engage the clutch and I have also had a bad clutch coil cause a problem. This year I had to replace my compressor, the system was charged and the clutch engaged just no flow from the compressor. |
You might try these guys.
GM 21030824 Switch, genuine OEM part Or these. https://www.wholesalegmpartsonline.c.../21030824.html And now I'M done too. |
