Radiator fan
Old Dec 13, 2024 | 07:53 AM
dreinhart's Avatar
Default Radiator fan
I have a 2008 vue.
When you turn the key on one fan starts up and running. Keeping the car to take more time to heat up.
What can cause the fan to turn on to soon.
Old Dec 13, 2024 | 10:08 AM
  • Bad engine coolant temperature sensor
  • Is AC accidentally engaged?
Old Dec 13, 2024 | 10:22 AM
dreinhart's Avatar
I haven't checked the AC yet but will.
Old Dec 13, 2024 | 01:43 PM
How did you check the temperature sensor?
Also, the AC has a relay most likely in the underhood junction box. The AC will run only if this relay is closed. It is usually commanded by the BCM to close as appropriate. It is possible that the relay is stuck closed so even if the AC is not on, the relay may be stuck closed.
These are general comments not specific to a 2008 VUE.
​​​​​​Don't know which engine you have, trim level etc. Please add. Not that any of that would affect AC operation. There's a chance the AC relay is actually integrated into the BCM. I'm simply not sure.
Old Dec 13, 2024 | 05:22 PM
grcauto8453's Avatar
Is the HVAC unit in defrost mode?
Old Dec 15, 2024 | 07:37 PM
redview's Avatar
The front fans are both powered through relays as well in the underhood fuse box: https://fuse-box.info/saturn/saturn-...uses-and-relay
There are two relays according to that fusebox diagram, "Cooling Fan Main" and "Cooling Fan Aux". I would try just switching those two relays around and seeing what happens - if your other fan now becomes the problem one that turns on too early, then you will know you have a bum relay.
Old Jan 16, 2025 | 08:24 AM
Stove's Avatar
I had similar issue. 1 fan running at hi speed. I unplugged both fan connectors and cleaned them and reseated them and now both fan runs like expected. With lo and hi speeds.
OneSaturnGuy
Sep 3, 2024 09:30 PM
Aspenglade
Mar 17, 2024 08:56 PM
LJ57
Oct 29, 2019 04:51 AM
annedonnell
Mar 21, 2011 09:19 PM
gbelous
Jul 10, 2007 01:44 PM
