Question
I will have to try that .
It don't vibrate b4 just couldn't tell because the center bear . and there no marks for the driveshaft to line up . i should of mark it but didn't think b4 Hand just wanted to fix it
All the u-joints should line up if you see what I mean. I don’t know if the center yoke has a master spline on your car. If there is a master spline the yoke will only go on the splines one way. On your original posting you were looking for the snap ring the holds the driveline together. That is where most drivelines shake if you misaligned the splines. As long as you did not bend the tubes when replacing the joints.
