P0122,P0123,P0223 no matter what I do
Old Mar 17, 2023 | 07:35 AM
https://obd2pros.com/dtc-codes/p0122/
Throttle pedal position sensor/switch circuit A low input.
occurs when the Engine Control Module (ECM) registers a reading below 2 volts from Throttle Pedal Position Sensor/Switch (TPS).
https://obd2pros.com/dtc-codes/p0123/
Throttle pedal position sensor/switch circuit A high input
The malfunction gets triggered when the TPS circuit A range output to the ECM exceeds 4.54 volts for more than two seconds.
https://obd2pros.com/dtc-codes/p0223
Throttle pedal position sensor/switch circuit B high inputthe throttle/pedal position switch/sensor B circuit is reading at a higher than the manufacturer specified voltage or amperage.. presumably 4.54 volts like circuit A.
There are specs out there. I cannot guarantee these are 100% correct given the rate of speed at which I found and copied them. But they are out there. Google is your friend
Old Mar 20, 2023 | 09:14 AM
thumper70's Avatar
thanks derf. I have been sick for awhile, just a miserable cold, so I have not had a chance to look further. I'll let everyone know what I find when I feel better. As we all know working on cars is a form of self abuse.
John Hasse
Jan 19, 2023 07:21 AM
Msmith6589
Dec 11, 2018 12:13 AM
02 LW300
Aug 13, 2015 04:11 AM
trysten
Mar 5, 2007 07:33 PM
