odometer light
Old Feb 18, 2008 | 11:14 AM
TonyT's Avatar
The odometer on my 2005 VUE no longer lights up. Blown fuse ???
Old Feb 20, 2008 | 01:05 PM
Low Saturn's Avatar
Is it just the light that illuminates the odometer or all the lights that illuminate the entire cluster that are out?
Old Feb 21, 2008 | 04:33 PM
TonyT's Avatar
Just the light that illuminates the odometer.
Help.
Old Feb 21, 2008 | 04:45 PM
original007's Avatar
The bulb is replaceable need to remove the cluster.Most likley need to get the bulb from the dealer.
Old Mar 22, 2008 | 12:36 PM
john95SW2's Avatar
Easy fix - dead bulb - bulb is $ 8.00 at the dealer...Remove IP trim - 2 screws on top & pull straight outRemove 4 hex head screws on 4 sides of IP - pull IP straight out.Remove odometer bulb - its the white one close to the bottom - remove it by turning it 1/4" counter clockwise Replace bulb...Install is reverse of removalEdited by: sw2cam
Old Jun 29, 2008 | 11:02 AM
RoyaL-Blue-Vue's Avatar
do you by anychance know the bulb number. cause i''d like to replace mine with a blue bulb to match my blue theme[img]smileys/smiley2.gif[/img]
Old Jun 29, 2008 | 08:46 PM
john95SW2's Avatar
Originally Posted by RoyaL-Blue-Vue
do you by anychance know the bulb number. cause i''''d like to replace mine with a blue bulb to match my blue theme[img]smileys/smiley2.gif[/img]
Saturn P/N 21019273 - dealer only part...
rileysowner
Mar 20, 2016 10:34 PM
Abe'sGST
Mar 28, 2012 08:41 PM
refinnejm
Jun 13, 2011 09:51 AM
saturn28027
Oct 9, 2006 12:45 AM
ray3483
Mar 15, 2006 12:03 PM
