Loss of power to ignition/accessories
Old Sep 8, 2010 | 05:12 PM
Furious's Avatar
Default Loss of power to ignition/accessories
2003 Saturn Vue Ecotec 2.2L L4 (4 cyl)
Tried to turn engine over, with no response from car. (like I had not even put the key in). Key turns, but there is a loss of connection somewhere.
Changed ignition cylinder (been meaning to do that for a while anyhow), and ignition switch.
Car still refuses to start.
Any suggestions would be appreciated.....
Old Sep 9, 2010 | 02:42 PM
hoseppi's Avatar
You may want to check your battery connections and the condition of the battery.
Old Sep 9, 2010 | 06:04 PM
+1 bone dead is often battery
and it's 7 years so orig battery may have gone south (if the orig was a 7 year that is...)
Old Sep 11, 2010 | 06:08 PM
Furious's Avatar
Battery works fine. I'm still able to turn headlights/interior lights on. Anything associated with the ignition ie; radio, power windows, starting.. wont work.
I have also checked fuses. Any idea if the ignition assembly (part that holds the switch/cylinder/and steering column lock all together) has an electronic security to it that I'm missing?
Old Sep 12, 2010 | 12:27 PM
I'm sure you have checked the 30amp IGN fuse located in the engine compartment fuse box, and also checked to confirm the presence of +12 volts on the heavy RED wire coming from that fuse to the ignition switch ............
gottabigtruck
Jun 1, 2011 07:29 PM
1999_Saturn
May 28, 2009 03:18 PM
only1jack
Jun 30, 2008 12:39 PM
RyeTerrell
Feb 19, 2007 12:33 PM
jimmysinks
Jul 11, 2005 10:19 PM
