check engine light with no code
Old Sep 14, 2009 | 01:00 PM
knorr713's Avatar
Question check engine light with no code
Hi all i'm new to the forum but I was hoping someone might have a suggestion. I have a 2005 saturn vue and all of a sudden I started it up and as I drove down my street the check engine light started to flash and I was having power and lurching problems. Same as I have had before in other cars when I get bad gas. Light has since gone solid in low gears and low RPM and flashes in higher gears and high RPM. Autozone did the diagnostic and it said everything was fine. I know its not because I am still having power problems and rattling problems. Two tanks of gas later thats not the problem. What could cause it to be fine one day and the next it feels like its going to fall apart. Any help would be great thanks.
Old Sep 14, 2009 | 08:51 PM
Autozone is fine for reading normal trouble codes (Pxxx) codes.
Be sure the reader used can also pull transmission trouble codes.
If all else fails, take it to Saturn before you damage something
Old Sep 15, 2009 | 07:10 AM
knorr713's Avatar
would it still be a transmission problem if it acts up while it is idle and it is a manual transmission?
Old Sep 16, 2009 | 07:20 PM
could be. Get the codes read properly -- including tranny codes
Old Apr 2, 2010 | 08:08 PM
AutoZone .............. LOL
Old Apr 2, 2010 | 09:57 PM
Which engine do you have in your VUE ??
Old Apr 3, 2010 | 10:02 AM
guess he never did get those tranny codes (or he's hiding them)
waterdish
May 29, 2009 11:32 PM
markdonn
Jul 4, 2007 07:03 PM
rockcandy
May 19, 2007 05:35 PM
zachary1988
Oct 20, 2005 03:22 PM
rufusnruby
Aug 6, 2005 10:54 PM
