check engine light
Old Aug 9, 2020 | 01:41 PM
Doozy's Avatar
Originally Posted by 02 LW300
I would drive it some before throwing money at it. You report it runs fine and you are concerned due to the check engine light not by poor running. Let us know how many miles on the car and do you have any repair history from a previous owner?
Has 134000 miles. The guy I bought it from told me he had recently replaced an O2 sensor.
Old Aug 9, 2020 | 04:52 PM
It is a timing belt engine, I wonder if the timing belt is a tooth off. With the mileage you have I hope it has been changed along with the water pump. I would want to look at that before doing anything else to it.
Old Aug 10, 2020 | 03:37 PM
Chickenbone's Avatar
Like they said above; get the codes and post them. I already had an OBDII scanner when my Aunt's Vue was giving her trouble. I pulled a P0430; which turned out to be a multiple cylinder misfire. I had already bought plugs and coils because I was planning on a full tune up anyways. I changed them out and the check engine light went out; for a day and lit back up. Next time I see my Aunt; I will break out the scanner and see if I get the same code. If so, I will look into replacing the intake gasket. Point is, diagnose the problem before buying parts.
Old Aug 10, 2020 | 04:52 PM
Per the above multiple responses and discussion, the codes are already posted.
Interesting you did not get a p0300 for random multiple misfires. Solidifies somewhat Andy's hunch.
ekeiger
Jul 1, 2012 07:31 PM
mrtweaver
Aug 30, 2011 11:54 PM
waterdish
May 29, 2009 11:32 PM
Liisa
May 1, 2006 12:51 PM
