CHARGING Issue
Old Jun 30, 2021 | 01:33 PM
Rob1087's Avatar
Default CHARGING Issue
Hi all, new member here.
Just put a starter in a friend's 2008 Vue 4 cylinder, now it's not charging. 10 volts and dropping. I'm at wits end with this car
Help!
Old Jun 30, 2021 | 05:13 PM
Did you check the battery connection at the alternator is clean and tight? Same thing at the battery end of that cable. Same thing for the negative terminal of the battery and where the negative cable grounds on the frame.
Corrosion free and tight connections are a must wind dealing with the charging system. Also, try to bend the cable at the battery about 2 in from the end. If it is all crunchy, acid has gotten to the cable and it will need to be replaced.
Once you clean up the connections, take it to AutoZone or similar and get a free load test on your charging system. It will tell you whether the alternator or the battery or something else is the issue.
For example, how do we know that you didn't have a marginally bad cell in your battery that was getting abused by trying to start the vehicle with the dying starter. Now that you have a new starter in there, that cell may still be deteriorating further
It's too expensive these days to play guessing games.
Old Jun 30, 2021 | 07:01 PM
Rob1087's Avatar
I found the issue. Was another cable I didn't see, sandwiched between the starter and engine block. All good.
thanks for replying
krispy261
Feb 24, 2025 09:35 PM
cruizin54
May 15, 2020 10:44 PM
Michael Grimes
Saturn Outlook
Sep 4, 2019 07:27 PM
lokiscarlet
Feb 12, 2016 02:28 PM
RobertR75
Jun 14, 2015 10:37 PM
