Anyone ever seen this or if it is fixable?
Old 11-24-2021, 09:37 PM
sddaltongang@hotmail.com's Avatar
Default Anyone ever seen this or if it is fixable?
I have a 2005 Saturn Vue with 57000 miles on the V6. Recently when I sent it to my garage for repair they discovered these significant rust out areas which in their opinion make it 'unsafe' to drive. The one on the drivers side has literally almost disintegrated the lower shock absorber support, & the passenger side is almost as bad. They suggested that I take it to a 'body shop' to see if they could repair it, which I might have to do unless some of you have some needed insights, suggestions, experiences with this kind of thing.
Old 11-24-2021, 10:57 PM
DropDead's Avatar
Common rust spot on the vue. It'll need to be cut out and repaired.
you must live up north.
Other option would be to find a southern shell with a blown engine and swap yours into
Old 11-25-2021, 07:34 PM
Thank you 'DropDead'! I think we will most likely just sell it 'as is', as it is also most likely in need of a 'rear main seal' replacement.
Not sure how to price it though, any suggestions would be appreciated.
Thank you again!!!
Old 11-26-2021, 05:33 AM
DropDead's Avatar
I live on Texas. That'd be a $500 car around me due to the rust and rear main. Someone would use it as a demolition derby car.
not sure for up there. Probably same ball park though
Old 11-26-2021, 07:08 AM
Are there any 'other' likely rust areas that I haven't already discovered, or that I should look into if I decide to keep it?
Old 11-26-2021, 08:41 AM
DropDead's Avatar
Thats the most common. Battery tray. And I think something with the rear suspension if I remember right
Old 11-26-2021, 10:08 AM
Thumbs up
Thank you once again DropDead!!!
Old 11-26-2021, 06:55 PM
DropDead's Avatar
not a problem. any other questions/comments/concerns please feel free to post away!
07-28-2020 01:55 AM
CDCallahan
07-20-2019 04:11 AM
budsjlm
10-17-2009 10:25 PM
budsjlm
09-16-2009 03:22 PM
PhantomLover007
17
10-21-2008 12:08 AM
Quick Reply: Anyone ever seen this or if it is fixable?
