4t45 trans leak
Old May 31, 2021 | 10:29 PM
New07Vue2.2's Avatar
Default 4t45 trans leak
I have a 2007 Saturn vue 2.2l fwd with the 4t45 trans. The Transmission has been leaking since i bought it, I thought it was the pan gasket but it was still leaking after i replaced it. I thought maybe it was cause I used a low quality gasket so I redid it with a good gasket. Also I cleaned off pretty much the entire transmission. Now it's Still leaking. It's not coming from the pan gasket though like i thought. It looks like it's coming from above it on the inside bend. Anyone know all the possible leak points and maybe what i should be looking at next?
I'll post a picture of it tomorrow when it's light out.
Thanks again!
​​​​​​​Red
Old Jun 1, 2021 | 08:33 AM
I've never even looked under the hood of a Vue, Red, so can't really tell you for sure, but I'd be checking where the transmission lines are routed and look for leaks on them. Also, if it has a spin on filter like the 1.9 engines do, I'd make sure the filter is not leaking.
Old Jun 1, 2021 | 07:41 PM
Default Pictures
Here's some pictures of where the fluid seems to be coming from its I the right side of the transmission .
The black at the bottom is the pan.
The pan is on the left
Old Jun 2, 2021 | 11:35 AM
Is that a dent in the casing by the uppermost bolt in the first picture?
Also is that the fill level check plug?
Old Jun 2, 2021 | 12:02 PM
No derf, there's no deformities, the pan is brand new. The top right bolt in picture one is the same as the bolt all the way to the bottom right in the second and third pictures. There's a drop of trans fluid dropping off it. And no the fill check bolt is off screen to the left in the first picture.
Old Jun 2, 2021 | 11:01 PM
Got it now. The angle of that first picture threw me off.
Unfortunately I am not a transmission guy. I was hoping for the easy solve. Hopefully others will chime in who know more about the particulars
Old Jun 2, 2021 | 11:05 PM
I'm not a transmutation guy either. Thanks anyway.
Old Jun 3, 2021 | 08:42 AM
I will look this weekend. I have one on the floor in the shop.
Old Jun 3, 2021 | 09:30 AM
I'm not a transmission guy either, but I'd suspect a front pump seal is leaking. Unless that's motor oil and not trans fluid. If it's motor oil, then I'd say the rear main seal is leaking.
Old Jun 3, 2021 | 10:02 AM
Thanks. Pump seal is somewhere to start..
98satsl1
Mar 23, 2016 07:57 PM
benwade
Jul 1, 2013 06:06 PM
Dr.Dodge
Dec 24, 2009 12:32 PM
JBNJ
Oct 22, 2009 07:14 AM
portum89
Oct 25, 2007 08:15 AM
