3.5L V6 Transmission Pressure Switches
I recently purchased a 2006 Base Vue (FWD) with the Honda V6/5 speed automatic transmission. It has a mild case of the low rpm shudder issue that is apparently notorious in these Honda transmissions.
As a first step, I will change the transmission fluid (several times) as well as replace the 3rd gear and 4th gear transmission pressure switches.
My question is if anyone knows the correct Honda part numbers for these pressure switches.
Thanks.
Thanks.
Bobbed06
10-31-2012 09:09 AM
