2009 Saturn Vue Xe 2.4L not starting
Old Feb 5, 2024 | 04:14 PM
stantheman's Avatar
Default 2009 Saturn Vue Xe 2.4L not starting
My car stopped starting so i tapped the starter and it started, i knew i needed to replace my starter. next day i come from work and my saturn doesn’t seem to start which i knew it was the starter, so i lightly tap it again while someone else was turning the key and it started smoking so i got a new starter and replaced it and still doesn’t want to start, i don’t know if i put in the starter wrong or not but i tried to switch all the wires in different places and still doesn’t wanna work. can someone please explain or help me if i did install wrong or not
Old Feb 6, 2024 | 01:14 AM
I'd like to try to help you.
But if you burned up a starter motor (presumably wired incorrectly) and are now switching electrical connections in search of the correct setup, I must conclude that your understanding of electrical circuitry is not sufficiently high enough to continue this as a diy repair.
​​​​​​I recommend taking this vehicle to a trusted mechanic. Mention to them that there may be a grounding issue at the transmission case where the PNP switch gets its ground.
Old Feb 6, 2024 | 08:21 AM
Hunter49x's Avatar
Default PNP switch?
You may be right about his skill level but using TLAs to describe his problems doesn’t help with understanding what his issue is? Also does it turn over but not start or just no activity at all when the key is turned to start?
Old Feb 6, 2024 | 07:55 PM
I respectfully declined to engage on this one.
Personal criticism of my non-involvement belongs somewhere other than a user's inquiry.
If you wish to delve into this, please go ahead.Thanks.
Old Feb 6, 2024 | 09:51 PM
grcauto8453's Avatar
I do not want to give him any instructions.
If he burns the car ti the ground I don;t want to be involved.
I recommend he not touch his car.
Old Feb 7, 2024 | 08:10 AM
And since I've never even looked under the hood of a Vue, I'm out.
yaazh
Saturn Aura
20
Oct 3, 2024 10:27 AM
cb1987
May 25, 2010 05:19 PM
xtremezx2
Feb 13, 2007 11:07 AM
jasontut
Feb 6, 2007 09:15 PM
TurboGN86
Sep 17, 2006 08:08 PM
