2007 Saturn Vue 3.5 V6 Ac problems
Old Aug 14, 2024 | 07:12 PM
954saturn's Avatar
Default 2007 Saturn Vue 3.5 V6 Ac problems
Hello everyone I have 2007 Saturn Vue 3.5 V6 it has 125k started to have a/c issues. While I was driving my ac stopped blowing completely, so I tested the ac resister it was bad so went ahead and replaced it then the ac start up like nothing. its been 2 months and the ac did the same exact thing just stopped blowing. I checked the the blower motor and worked just fine what else could it be. Does anyone know where is the ac pressure switch located on a 2007 3.5 v6? Or what else could it be if anyone can help please
Old Aug 14, 2024 | 08:15 PM
grcauto8453's Avatar
So you had a blower resistor problem. Do you have a blower now? Does the compressor work? I can't tell if you have an AC problem or a blower motor problem.
Old Aug 14, 2024 | 10:29 PM
Greg,
Are they maybe referring to the air conditioning diode usually found in the underhood fuse box? Especially since the resistor pack and all that good stuff runs off DC not AC.
I never have looked up to see what that diode does in the AC system......
Old Aug 15, 2024 | 09:23 AM
The diodes are used in high current circuits to bleed off eddies produced when a coil collapses. They are a protective devise.
Old Aug 15, 2024 | 12:14 PM
Thank you, sir.
Alphabet
Jul 30, 2024 02:38 PM
Ena
Jun 24, 2024 08:00 AM
mitch.dhi
Oct 22, 2023 10:26 AM
ptashley19
Jun 6, 2021 10:17 PM
Partyrider
Jul 1, 2018 03:13 AM
