2006 vue evap leak.
Old 01-28-2020, 05:21 PM
ManceMajors's Avatar
Default 2006 vue evap leak.
I am a complete noob. I have a 2006 4cyl vue. 2.2 ltr. I am getting a gross evap leak code. Car runs a little rough. Is there anything in this test that can tell me anything. Where the leak may be?
Mode $06 report generated by Torque for Android
Vehicle VIN: 5GZCZ33DX6S858414
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: 12604014
12593705
Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
Test report:
TID:$02 CID:$04
- Lean to Rich sensor threshold voltage(constant)
Test incomplete or dependant test failed
TID:$02 CID:$06
Min: 32,828
Test result value: 32,828
PASS
TID:$02 CID:$11
Min: 80
Test result value: 80
PASS
TID:$02 CID:$30
TID:$02 CID:$40
TID:$02 CID:$50
Min: 32,867
Test result value: 32,797
FAIL
TID:$02 CID:$60
Max: 33,008
Test result value: 33,008
PASS
TID:$02 CID:$62
Max: 32,768
Test result value: 32,768
PASS
TID:$02 CID:$66
Max: 32,888
Test result value: 32,693
PASS
TID:$02 CID:$71
Max: 32,818
PASS
TID:$02 CID:$72
Max: 32,768
PASS
TID:$05 CID:$01
- Rich to Lean sensor switch time(calculated)
Max: 65,535
Test result value: 17,778
PASS
TID:$05 CID:$02
Max: 65,535
Test result value: 16,944
PASS
TID:$05 CID:$03
Max: 65,535
Test result value: 11,250
PASS
TID:$05 CID:$04
Max: 65,535
Test result value: 20,833
PASS
TID:$05 CID:$05
Max: 7,688
Test result value: 2,375
PASS
TID:$05 CID:$06
Max: 5,250
Test result value: 2,125
PASS
TID:$05 CID:$07
Min: 55
Test result value: 149
PASS
TID:$05 CID:$08
Min: 55
Test result value: 150
PASS
TID:$05 CID:$0b
Min: 23,200
Test result value: 23,200
PASS
TID:$05 CID:$0c
Max: 9,600
Test result value: 6,720
PASS
TID:$05 CID:$0d
Max: 64,767 Min: 29,568
Test result value: 32,772
PASS
TID:$0c CID:$60
- Misfire counts for last/current driving cycles(calculated)
Max: 32,871
Test result value: 31,418
PASS
TID:$02 CID:$04
TID:$02 CID:$06
Min: 32,828
PASS
TID:$02 CID:$11
Min: 80
PASS
TID:$02 CID:$30
TID:$02 CID:$40
TID:$02 CID:$50
Min: 32,867
FAIL
TID:$02 CID:$60
Max: 33,008
PASS
TID:$02 CID:$62
Max: 32,768
PASS
TID:$02 CID:$66
Max: 32,888
PASS
TID:$02 CID:$71
Max: 32,818
PASS
TID:$02 CID:$72
Max: 32,768
PASS
TID:$05 CID:$01
Max: 65,535
PASS
TID:$05 CID:$02
Max: 65,535
PASS
TID:$05 CID:$03
Max: 65,535
PASS
TID:$05 CID:$04
Max: 65,535
PASS
TID:$05 CID:$05
Max: 7,688
PASS
TID:$05 CID:$06
Max: 5,250
PASS
TID:$05 CID:$07
Min: 55
PASS
TID:$05 CID:$08
Min: 55
PASS
TID:$05 CID:$0b
Min: 23,200
PASS
TID:$05 CID:$0c
Max: 9,600
PASS
TID:$05 CID:$0d
PASS
TID:$02 CID:$04
TID:$02 CID:$06
Min: 32,828
PASS
TID:$02 CID:$11
Min: 80
PASS
TID:$02 CID:$30
TID:$02 CID:$40
TID:$02 CID:$50
Min: 32,867
FAIL
TID:$02 CID:$60
Max: 33,008
PASS
TID:$02 CID:$62
Max: 32,768
PASS
TID:$02 CID:$66
Max: 32,888
PASS
TID:$02 CID:$71
Max: 32,818
PASS
TID:$02 CID:$72
Max: 32,768
PASS
End of report.
Old 01-28-2020, 06:12 PM
DropDead's Avatar
What's the codes? Sounds like an o2 sensor. I'm not familiar with these new scanners though. Check engine lights only worry me when they go off.
Old 01-28-2020, 06:39 PM
i hear ya. I just got this scanner. I know nothing about it. Ive been trying to run down this evap leak forever
Old 01-29-2020, 08:13 AM
Have you tried just cleaning the gas filler neck and gas cap? Sometimes that's all it is. Check the O-ring on that gas cap too. If it looks the least bit sketchy, get another gas cap and try that.
Old 01-31-2020, 11:31 PM
Pls post all codes currently stored as Pxxxx not the description of the codes.
dwain1968
05-06-2019 10:44 PM
Erika12971
07-06-2013 11:17 AM
Claplume
04-23-2013 12:37 PM
sep25
07-24-2011 10:56 AM
jdd3098
12-28-2008 09:58 PM
Quick Reply: 2006 vue evap leak.
