2006 vue evap leak.
I am a complete noob. I have a 2006 4cyl vue. 2.2 ltr. I am getting a gross evap leak code. Car runs a little rough. Is there anything in this test that can tell me anything. Where the leak may be?
Mode $06 report generated by Torque for Android ================================================ Vehicle VIN: 5GZCZ33DX6S858414 Vehicle Manufacturer: Unknown Vehicle Calibration ID: 12604014 12593705 Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended. Test report: ------------------ TID:$02 CID:$04 - Lean to Rich sensor threshold voltage(constant) Test incomplete or dependant test failed -- TID:$02 CID:$06 - Lean to Rich sensor threshold voltage(constant) Min: 32,828 Test result value: 32,828 PASS ---- TID:$02 CID:$11 - Lean to Rich sensor threshold voltage(constant) Min: 80 Test result value: 80 PASS ---- TID:$02 CID:$30 - Lean to Rich sensor threshold voltage(constant) Test incomplete or dependant test failed -- TID:$02 CID:$40 - Lean to Rich sensor threshold voltage(constant) Test incomplete or dependant test failed -- TID:$02 CID:$50 - Lean to Rich sensor threshold voltage(constant) Min: 32,867 Test result value: 32,797 FAIL ---- TID:$02 CID:$60 - Lean to Rich sensor threshold voltage(constant) Max: 33,008 Test result value: 33,008 PASS ---- TID:$02 CID:$62 - Lean to Rich sensor threshold voltage(constant) Max: 32,768 Test result value: 32,768 PASS ---- TID:$02 CID:$66 - Lean to Rich sensor threshold voltage(constant) Max: 32,888 Test result value: 32,693 PASS ---- TID:$02 CID:$71 - Lean to Rich sensor threshold voltage(constant) Max: 32,818 Test result value: 32,693 PASS ---- TID:$02 CID:$72 - Lean to Rich sensor threshold voltage(constant) Max: 32,768 Test result value: 32,768 PASS ---- TID:$05 CID:$01 - Rich to Lean sensor switch time(calculated) Max: 65,535 Test result value: 17,778 PASS ---- TID:$05 CID:$02 - Rich to Lean sensor switch time(calculated) Max: 65,535 Test result value: 16,944 PASS ---- TID:$05 CID:$03 - Rich to Lean sensor switch time(calculated) Max: 65,535 Test result value: 11,250 PASS ---- TID:$05 CID:$04 - Rich to Lean sensor switch time(calculated) Max: 65,535 Test result value: 20,833 PASS ---- TID:$05 CID:$05 - Rich to Lean sensor switch time(calculated) Max: 7,688 Test result value: 2,375 PASS ---- TID:$05 CID:$06 - Rich to Lean sensor switch time(calculated) Max: 5,250 Test result value: 2,125 PASS ---- TID:$05 CID:$07 - Rich to Lean sensor switch time(calculated) Min: 55 Test result value: 149 PASS ---- TID:$05 CID:$08 - Rich to Lean sensor switch time(calculated) Min: 55 Test result value: 150 PASS ---- TID:$05 CID:$0b - Rich to Lean sensor switch time(calculated) Min: 23,200 Test result value: 23,200 PASS ---- TID:$05 CID:$0c - Rich to Lean sensor switch time(calculated) Max: 9,600 Test result value: 6,720 PASS ---- TID:$05 CID:$0d - Rich to Lean sensor switch time(calculated) Max: 64,767 Min: 29,568 Test result value: 32,772 PASS ---- TID:$0c CID:$60 - Misfire counts for last/current driving cycles(calculated) Max: 32,871 Test result value: 31,418 PASS ---- TID:$02 CID:$04 - Lean to Rich sensor threshold voltage(constant) Test incomplete or dependant test failed -- TID:$02 CID:$06 - Lean to Rich sensor threshold voltage(constant) Min: 32,828 Test result value: 32,828 PASS ---- TID:$02 CID:$11 - Lean to Rich sensor threshold voltage(constant) Min: 80 Test result value: 80 PASS ---- TID:$02 CID:$30 - Lean to Rich sensor threshold voltage(constant) Test incomplete or dependant test failed -- TID:$02 CID:$40 - Lean to Rich sensor threshold voltage(constant) Test incomplete or dependant test failed -- TID:$02 CID:$50 - Lean to Rich sensor threshold voltage(constant) Min: 32,867 Test result value: 32,797 FAIL ---- TID:$02 CID:$60 - Lean to Rich sensor threshold voltage(constant) Max: 33,008 Test result value: 33,008 PASS ---- TID:$02 CID:$62 - Lean to Rich sensor threshold voltage(constant) Max: 32,768 Test result value: 32,768 PASS ---- TID:$02 CID:$66 - Lean to Rich sensor threshold voltage(constant) Max: 32,888 Test result value: 32,693 PASS ---- TID:$02 CID:$71 - Lean to Rich sensor threshold voltage(constant) Max: 32,818 Test result value: 32,693 PASS ---- TID:$02 CID:$72 - Lean to Rich sensor threshold voltage(constant) Max: 32,768 Test result value: 32,768 PASS ---- TID:$05 CID:$01 - Rich to Lean sensor switch time(calculated) Max: 65,535 Test result value: 17,778 PASS ---- TID:$05 CID:$02 - Rich to Lean sensor switch time(calculated) Max: 65,535 Test result value: 16,944 PASS ---- TID:$05 CID:$03 - Rich to Lean sensor switch time(calculated) Max: 65,535 Test result value: 11,250 PASS ---- TID:$05 CID:$04 - Rich to Lean sensor switch time(calculated) Max: 65,535 Test result value: 20,833 PASS ---- TID:$05 CID:$05 - Rich to Lean sensor switch time(calculated) Max: 7,688 Test result value: 2,375 PASS ---- TID:$05 CID:$06 - Rich to Lean sensor switch time(calculated) Max: 5,250 Test result value: 2,125 PASS ---- TID:$05 CID:$07 - Rich to Lean sensor switch time(calculated) Min: 55 Test result value: 149 PASS ---- TID:$05 CID:$08 - Rich to Lean sensor switch time(calculated) Min: 55 Test result value: 150 PASS ---- TID:$05 CID:$0b - Rich to Lean sensor switch time(calculated) Min: 23,200 Test result value: 23,200 PASS ---- TID:$05 CID:$0c - Rich to Lean sensor switch time(calculated) Max: 9,600 Test result value: 6,720 PASS ---- TID:$05 CID:$0d - Rich to Lean sensor switch time(calculated) Max: 64,767 Min: 29,568 Test result value: 32,772 PASS ---- TID:$02 CID:$04 - Lean to Rich sensor threshold voltage(constant) Test incomplete or dependant test failed -- TID:$02 CID:$06 - Lean to Rich sensor threshold voltage(constant) Min: 32,828 Test result value: 32,828 PASS ---- TID:$02 CID:$11 - Lean to Rich sensor threshold voltage(constant) Min: 80 Test result value: 80 PASS ---- TID:$02 CID:$30 - Lean to Rich sensor threshold voltage(constant) Test incomplete or dependant test failed -- TID:$02 CID:$40 - Lean to Rich sensor threshold voltage(constant) Test incomplete or dependant test failed -- TID:$02 CID:$50 - Lean to Rich sensor threshold voltage(constant) Min: 32,867 Test result value: 32,797 FAIL ---- TID:$02 CID:$60 - Lean to Rich sensor threshold voltage(constant) Max: 33,008 Test result value: 33,008 PASS ---- TID:$02 CID:$62 - Lean to Rich sensor threshold voltage(constant) Max: 32,768 Test result value: 32,768 PASS ---- TID:$02 CID:$66 - Lean to Rich sensor threshold voltage(constant) Max: 32,888 Test result value: 32,693 PASS ---- TID:$02 CID:$71 - Lean to Rich sensor threshold voltage(constant) Max: 32,818 Test result value: 32,693 PASS ---- TID:$02 CID:$72 - Lean to Rich sensor threshold voltage(constant) Max: 32,768 Test result value: 32,768 PASS ---- End of report. |
What's the codes? Sounds like an o2 sensor. I'm not familiar with these new scanners though. Check engine lights only worry me when they go off.
Originally Posted by DropDead
(Post 63920)
Have you tried just cleaning the gas filler neck and gas cap? Sometimes that's all it is. Check the O-ring on that gas cap too. If it looks the least bit sketchy, get another gas cap and try that.
Pls post all codes currently stored as Pxxxx not the description of the codes.
