2005 Vue 3.5 loose pulley on the alternator
Old Apr 2, 2021 | 10:18 AM
Huggytree's Avatar
Default 2005 Vue 3.5 loose pulley on the alternator
Engine started making grinding noises. Took the belt off and the alternator pulley is very sloppy. Is there a way to tighten it ? Without removing the alternator ?
Old Apr 2, 2021 | 10:22 AM
oldmarine's Avatar
Likely it's not the pulley itself but the bearing. You'll need to replace the alternator.
Old Apr 2, 2021 | 10:31 AM
Huggytree's Avatar
the pully should not be loose though correct?
looks like i gotta lift the engine
Old Apr 2, 2021 | 10:36 AM
oldmarine's Avatar
The pulley should spin smoothly and with no radial movement. There should be no noise or vibration when spinning the pulley.
Old Apr 2, 2021 | 11:36 AM
Huggytree's Avatar
Took the main motor mount bolt out. Jacked up the engine and the engine wouldn’t raise by itself. So I started to take the 2 top mount bolts out. Sheared one right off. Guess it’s going to the repair shop
giving Up
Old Apr 2, 2021 | 09:48 PM
DropDead's Avatar
I have an alternator I can sell cheap
wcervant
Saturn L300
Dec 14, 2017 11:49 PM
jchubb01
Jun 19, 2012 09:16 PM
Squiz
Apr 24, 2012 11:37 AM
silverplumsat
Nov 1, 2005 10:39 PM
