2005 Vue 3.5 loose pulley on the alternator
Engine started making grinding noises. Took the belt off and the alternator pulley is very sloppy. Is there a way to tighten it ? Without removing the alternator ?
Likely it's not the pulley itself but the bearing. You'll need to replace the alternator.
the pully should not be loose though correct?
looks like i gotta lift the engine |
The pulley should spin smoothly and with no radial movement. There should be no noise or vibration when spinning the pulley.
Originally Posted by oldmarine
(Post 66723)
giving Up |
I have an alternator I can sell cheap
