2005 Vue 2.2L Oil Pan Removal
Old Nov 28, 2017 | 06:58 PM
sporatica's Avatar
Default 2005 Vue 2.2L Oil Pan Removal
Hi, I could really use some guidance or an exploded view diagram of what I'm doing here. 2005 Vue 2.2L. I'm working in the blind.
A diagram would be extremely handy. Any and all help is greatly appreciated.
We took a rock to the oil pan causing it to leak out nearly all of the oil. I have not started the engine. It's up on a jack with jack stands.
I drained all of the remaining oil and replaced the drain plug. I've ordered a new pan, but am unsure of all that I need to disconnect in order to cleanly drop the current oil pan. The oil drained out in the driveway.
We were able to push it into the carport, but don't have the $$$ to tow it to a shop. Bottom line is I have to do this myself and don't want to disconnect anything I don't have to remove/disconnect. I think I'm ready to remove the loosened bolts from the oil pan, but want to make sure I'm not missing anything.
I disconnected the negative battery terminal, removed one large bolt from the alternator mount, the bolt from the AC pump and the bolt holding dipstick tube up top. I've loosened the bolts on the bottom of the oil pan, removed the right splash guard to access the bolts up under there. I read that I would have to remove the motor mount to access these but was able to get up under there.
Thank you in advance.
Serrena
Old Nov 29, 2017 | 10:14 AM
I don't really know, but if you're sure you've disconnected everything that could possibly be in the way, then I'd say go for it. Remove the oil pan bolts and ease the pan down to see if anything else is in the way. If not, then remove it. Make sure you thoroughly clean the block surface before installing the new one. I don't even know if it takes a gasket or just RTV, like some of them do nowadays. You really need to find the proper torque for the bolts, as you don't want to strip one out in the aluminum.
Old Dec 31, 2017 | 02:40 PM
sporatica's Avatar
Default Oil Pan Installed
The new oil pan is in. Two bolts under the right motor mount were a bit difficult, but I gained access by removing the mudflap. The dipstick tube fought the good fight, but eventually popped out. I installed new o-rings, just in case.
I didn't have to raise the engine, and that's the one thing I would not have been able to do. Thank you all for the diagrams, advice and sharing of knowledge.
Old Jan 1, 2018 | 07:55 AM
Glad to hear you got it fixed. Happy motoring.
Cdelaney
Jan 19, 2013 10:56 AM
veganxxx
Apr 29, 2011 08:23 AM
JBNJ
Oct 22, 2009 07:14 AM
rossjohna
Oct 23, 2007 10:45 PM
rossjohna
Sep 15, 2007 01:22 PM
