2005 honda engine removal vue
Old Feb 22, 2019 | 01:43 PM
crom911's Avatar
Default 2005 honda engine removal vue
afternoon all,
i have a 2005 vue with the honda engine. my daughter drives it and somehow managed to break 2 of the motor mount bolts and strip the third one. i cannot get to the bolts easily to drill and remove them, trust me i tried. and i dont have access to a lift to drop the engine and tranny from the bottom. the engine has almost 280,000 on it so if im going to pull it i might as well replace it. my question is, is it possible from the top, leaving the transmission in place, or is through the bottom the only option?
Thanks in advance for the help
Old Feb 23, 2019 | 04:36 PM
I dug around on the net. All but one poster pulled the engine from the bottom by dropping the cradle and pulling engine and transmission together.
Old Feb 24, 2019 | 05:56 AM
Seems like you need to do some cribbing. Jack it up, put some blocks under it and continue until you have it high enough to get the clearance you need. I'm not talking about concrete blocks. I prefer large pieces of wood.
CephEsaul
Jan 6, 2020 04:43 PM
Anon93
Sep 8, 2019 11:30 AM
rperkins_911
May 13, 2018 10:30 AM
drivethegreen
Nov 19, 2014 10:44 PM
mike2009
Aug 29, 2009 11:47 PM
