2004 Vue does not accelerate in drive
Old Mar 12, 2014 | 10:07 AM
kzdcz3's Avatar
Default 2004 Vue does not accelerate in drive
Recently, my Saturn does not accelerate from a stop even though the car in drive. Engine will rev up, but car seems like it's in neutral. But If I shift the gear into park and back to drive, it will accelerate. I wonder is there something wrong? Does it need a new trans?
2004 FWD Vue Honda 3.5V6 with 95,000 miles.
Old Mar 12, 2014 | 12:47 PM
You "wonder" is there something?
Old Mar 12, 2014 | 06:27 PM
Definitely something wrong. Have you tried a transmission fluid and filter change? Do that with a little Lucas transmission treatment in there in place of a half quart of fluid.
Old Mar 14, 2014 | 08:22 AM
blaisa's Avatar
I also have a 2004 Vue with automatic issues. Where do you add tranny fluid, check tranny fluid level and change the filter? Mine only has 106k miles.
Old Mar 14, 2014 | 08:26 AM
I have never looked under the hood of a VUE. They don't appeal to me, so I've never bothered. If you don't have a transmission dipstick, then I don't have a clue. Maybe another VUE owner can enlighten you.
Old Mar 15, 2014 | 09:33 AM
blaisa's Avatar
Yup! No dipstick. Looked in a Haynes manual and it just says "add transmission fluid" nothing about where.
Old Mar 15, 2014 | 03:49 PM
There has to be a tube with a rubber plug in it somewhere at least. If not, then how the hell are you supposed to add fluid?
Old Mar 16, 2014 | 09:55 AM
blaisa's Avatar
Well when disassembling the Vue yesterday to drop the drivetrain out the bottom I found the fill cap. It is located under the battery box / fuse-relay box assembly. Well hidden. Only way to add oil is to remove these items. Real convenient! Sarcasm, of course. As for being able to tell if it is full? well that it another issue. I just dumped all the oil I had into the transmission and fired up the engine just to make sure the transmission was not working due to low fluid level, no such luck.
When I pulled the transmission fluid cooler lines the fluid that came out was glittering with gold flakes of metal. Not silver but gold. ???
harleypower69
Feb 20, 2021 06:45 AM
Bill Holcomb
Jul 19, 2010 02:58 PM
SC2
Apr 1, 2010 06:36 PM
PdPuNOme
Oct 17, 2009 06:55 AM
juggalo2929
Feb 25, 2007 04:32 PM
