07 Vue Gremlins
Old Jul 7, 2025 | 09:36 AM
Rdadeo's Avatar
Default 07 Vue Gremlins
Hey all.
Looking for some opinions on a couple things.
Code P0455 - Evap system leak... Evap codes are a nightmare on a lot of other vehicles. Trying to find the problem is like whack a mole. Is there a directiuon that fairly common with these cars?
Next one od the locking system. It should unlock the doors when you put er back into park, but this one does not do that. You can hear it locking them when you slip into D, but there is no attempt to lock them in park. the switches on the doors work fine tho and everything locks and unlocks like normal.
Any thoughts or advise on where to start?
Old Jul 7, 2025 | 08:17 PM
My Saturn will unlock the doors when I shift to park and shut the engine off, only when I remove the key will the doors unlock.
Old Jul 8, 2025 | 10:30 AM
Rdadeo's Avatar
Default Gremlins.
Interesting. I am going to have to play with mine a bit. But as far as I know. It does not unlock until I press the switch on the door.
Old Jul 8, 2025 | 11:48 AM
Found this in the 2007 Vue owner's manual.
Apparently it is programmable behavior.
Who knew?
Old Jul 8, 2025 | 04:01 PM
grcauto8453's Avatar
What problem are we working on?
EVAP leaks you need to charge the system with a few pounds and spray a with a mix of 1 part Simple Green and 10 parts water. You will see where the foam is.
Old Jul 8, 2025 | 07:06 PM
Working on auto door unlocking. It appears that the auto door unlock behavior can be enabled and disabled.
Old Jul 9, 2025 | 07:41 AM
Rdadeo's Avatar
Default Worked like a charm
Who knew?
This worked like a charm. It honestly never occured to me that it might be programmable. Thanks much!
GaryG
May 13, 2024 11:01 PM
danemodsandy
Saturn Aura
May 7, 2022 06:31 PM
Grbenda
Sep 7, 2019 02:37 PM
cellocellocello
Oct 13, 2009 10:47 PM
pester
Sep 5, 2008 03:25 PM
