Tow Dolly, moving Sky or Solstice...
Old 03-19-2016, 02:06 PM
a_bartle's Avatar
Default Tow Dolly, moving Sky or Solstice...
Has anybody used a tow dolly to move their Sky/Solstice? If you put them on backwards, then you wouldn't have to remove the drive shaft. I've done this with Fiero's in the past (the steering wheel locks in and I used the the seatbelt around it for added security) and had good luck. I was just wondering if there is something with the Kappa platform that would prevent me from doing this?
Similar to this....
Attached Thumbnails Tow Dolly, moving Sky or Solstice...-fiero_dolly_3.jpg   Tow Dolly, moving Sky or Solstice...-fiero_dolly_2.jpg
Old 03-19-2016, 02:14 PM
Is it legal to tow a rear engine car like that? I don't know, I'm just wondering.
Old 03-19-2016, 02:20 PM
Dave4422's Avatar
As far as I know, there's nothing wrong with reverse-towing. I think the only thing you need by law are extra brake lights on the car. As long as you have the drive wheels off the ground, you don't have to worry about the drivetrain. Hopefully the steering wheels will lock straight, otherwise it'll be a wild wiggle or crabbing!
Old 03-19-2016, 05:58 PM
as long as the steering wheel locks and you have another method to ensure its locked I wouldnt see a problem with it. if your renting a trailer a full on car trailer may be the way to go if the sky isnt too low. I would do alittle more research cause I think ive seen them flat-towed behind campers
Old 03-20-2016, 02:25 AM
goaliemo's Avatar
if renting, just get the bed. Its like an extra 10 dollars from uhaul, and don't have to remove body panels like I did with a dolly.
02 LW300
08-05-2015 07:14 AM
C6vette
01-26-2015 09:55 PM
Allison328
07-06-2007 05:57 PM
gsynth6
12-17-2006 05:03 PM
Quick Reply: Tow Dolly, moving Sky or Solstice...
