sl rear power windows.
Old Dec 17, 2008 | 11:27 AM
chriSL2's Avatar
is it common that the rear windows on the sl2 power windows fall of the tracks?
went to put the window down and it made some noise and then stopped, tried to put back up and wouldnt. so i had to pull it up.
Old Dec 17, 2008 | 01:06 PM
Well, I have owned a couple of SL2 vehicles in the past, but I have never had a problem with the windows falling off the track. Obviously, from your report, it can happen, but I have not had experience in this area ...
Old Dec 17, 2008 | 10:52 PM
Low Saturn's Avatar
Not common, but the rears can get stuck on 91-95 sedans/wagons the older the car gets and if the regualtor doesnt get lubricated.
Old Dec 18, 2008 | 03:48 PM
chriSL2's Avatar
yeah its a 96 sl2 and all the windows seem like there having trouble comeing down. thanks everyone
Old Jan 27, 2009 | 09:26 PM
tylerrf911's Avatar
have the same problems in my 1997 sl1 when its cold
Old Mar 9, 2009 | 07:01 PM
chriSL2's Avatar
well i just got around to fixing my rear windows and the plastic clips that slide in the tracks split in half. i also changed them on my gf''s car, same thing split in half. the guy at saturn said its common.
Old Apr 4, 2009 | 10:04 AM
scrapmedallord's Avatar
my driver side passenger window falls off, just dont use it anymore. the motor is still good cause i can hear it move up and down, but the window doesnt like to stay on. unless you have kids i wouldnt worry about it as long as it stays up
Old Apr 5, 2009 | 10:28 AM
saturn27429's Avatar
I have this same problem and I am trying to find out if I remove the inner or outer panel to check this?
Old Apr 5, 2009 | 12:52 PM
Actually, you remove the outer panel/skin to check this ....
hollywood32401
Dec 5, 2008 05:14 PM
coupeguy08
Nov 17, 2008 11:31 AM
shaggy187
May 17, 2008 05:31 PM
ASKBCG
Oct 1, 2007 08:17 PM
lilsizfly
May 6, 2007 06:19 PM
