SC2 Front Coil Spring
Old Mar 20, 2010 | 02:43 PM
teresadf's Avatar
Exclamation SC2 Front Coil Spring
The driver's side front coil spring on my 01 sc2 just snapped. Is there an easy way to replace this, or is it so complicated that I would need to have a mechanic do it? Also, if I DO take it to a mechanic, is it that big of a job where it would be pretty damn expensive to have replaced?
I've already got the coil springs priced & a compressor rental priced, just wondering if I should just let a mechanic do it, or spend the $120 for parts & compressor and do it myself. By myself, I mean my dad.
Thanks for any help you can provide.
Old Mar 20, 2010 | 05:21 PM
Easy to do, get an alignment when your done.
Old Mar 21, 2010 | 11:40 AM
hoseppi's Avatar
Or, you can go to one of those u pull it places and get the whole shock tower for about 45$ or less. You won't need the spring compressor. There are only 5 nuts/bolts holding it on.
Old Mar 21, 2010 | 01:22 PM
Curly's Avatar
pull it places?
Old Mar 21, 2010 | 05:27 PM
What he is referring to is a type of wrecking yard that allows you to remove the part you need from their fleet(?) of wrecked vehicles. Usually much cheaper than a traditional wrecking yard, where the parts have already been removed and cataloged ... and definitely cheaper than the local parts houses
Old Mar 21, 2010 | 06:02 PM
teresadf's Avatar
Thanks for all your help!
Old Mar 24, 2010 | 10:11 PM
teresadf's Avatar
We ended up getting a used strut assembly for $35 from a junk yard, then had Big O Tires remove the old assembly & put the other part on then do the alignment. All in all, I spent about $200 for parts and labor.
Old Mar 24, 2010 | 10:17 PM
Hopefully, that'll fix your problem(s) .....
Old Apr 5, 2010 | 01:41 PM
teresadf's Avatar
Well the coil spring is fixed, but my sunroof won't open/close. WTF? Saturn goes out of business & my car goes to ****?
Old Apr 5, 2010 | 06:15 PM
OMG your the only SATURN driver in the world that'll have to go to another GM dealer to buy parts.
Aug 13, 2015 06:19 PM
HitchAnything
Member Group And Special Buys
Mar 13, 2014 11:18 PM
'98 Saturn SC2
Suspension
16
Oct 2, 2013 07:05 PM
Sleepy SL
Suspension
Sep 1, 2011 07:57 PM
JC316
Feb 29, 2008 10:44 PM
