???? Saturn ??? whining noise
Old Nov 1, 2024 | 02:59 PM
Jacob987's Avatar
Default ???? Saturn ??? whining noise
Start your own thread next time in the correct section and fill
In year and model.
I have a whining noise coming from front driver side when turning left and accelerating but then slowly goes away. I replaced the valve body recently and changed trans fluid and filter and then the noise started happening. Sometimes if you try to get on the throttle it will whine a little bit and it does match the throttle response so it stops whining if I left off the throttle. I don’t know what I could of done wrong I’m hoping someone can help me out or point me in the right direction. Thanks
Old Nov 1, 2024 | 04:48 PM
Getting on the throttle when not turning left?
Can you reproduce this noise with a vehicle in park or neutral or only when it is in a forward gear?
Are you sure the transmission fluid level is full?
What did you use for transmission fluid?
Old Nov 2, 2024 | 11:59 AM
Pasted from private message
so I recently replaced the valve body and didn’t have any issues doing it. I also changed the fluid and filter and I used fram dextron-3 and put 4.5 quarts in the transmission and after all of that the whining noise started. It happens when making a left turn from a complete stop and then gradually goes away after and it matches the throttle so if I let off it stops whining and it will also whine a a little bit if I get on the throttle while going straight. It will also whine a little worse in the cold morning then will act how I said it normally acts once it warms up. It does not make the noise when the car is in park or neutral only in drive. I have no idea what would be causing this noise and I would really appreciate if you could point me in the right direction.
Old Nov 3, 2024 | 04:07 AM
axkoa's Avatar
Just offered a 2009 redline with 18000 miles. After per week of riding, I am noticing a whining noise among 45 and 55 MPH. Automatic transmission. Sounds love it is probably coming from differential. Any ideas?
Tutuapp 9Apps
Old Nov 3, 2024 | 08:02 PM
@axkoa
1. start your own thread.
2. In 1, include whether it is a Vue or a Sky red line
3. Point out the problem part from the door diagram i provided in your last thread.
4. Please respect your fellow forum members going forward.
It's to your benefit to do of the above in the next 72 hours.
Abonney
Sights N Sounds
Jan 16, 2022 04:47 PM
ASMobile
Jan 18, 2014 08:48 AM
tubbsey88
Jul 7, 2008 11:20 AM
tooicky
Jun 19, 2008 10:40 PM
latestgood
May 5, 2008 09:20 AM
