Rear hatch in 96 sw1 lever does not operate
Old Sep 30, 2009 | 03:53 PM
PdPuNOme's Avatar
Angry Rear hatch in 96 sw1 lever does not operate
I have a sw1 wagon 1996 and the lever on the driver floor when pulled does not pop the rear gate hatch. i have to use the key to open the hatch from the outside. anyone know any possible solutions?
Old Sep 30, 2009 | 08:24 PM
carterseth32's Avatar
Having the same prob wit my 2001 SC2. Could use the same advice.
Old Oct 12, 2009 | 06:41 PM
PdPuNOme's Avatar
does anyone have any input on this?
Old Oct 12, 2009 | 06:56 PM
In my 97 SC2 (Coupe) it is actually an electrically actuated switch that is operated by pulling the lever (which is connected to a cable). I've busted off part of the connector a few times when my tool box slid around in my trunk.
Check the latch in the trunk (the part connected to the trunk lid to see if there is any damage to the wiring that goes into it)
Not sure if this applies to 96 nor if it applies to 2001.....
Old Oct 12, 2009 | 11:12 PM
Derf has the 4/11 on the hatch release cable for the SW series -- good capture
Old Oct 13, 2009 | 06:13 PM
PdPuNOme's Avatar
I removed the hatch assembly on the hatch and cleaned the connectors with crc electrical spray and no difference still nothing so i am running to the u pull it and grabbing one out of the only wagon in any u pull it yard ive been to and trying that one. could there be a trunk release switch somewhere like other cars have usually in the glove box i cannot find one. also could the lever be bad anyone know what lerks down there?
Old Oct 13, 2009 | 06:25 PM
It's a cable that runs to the latch. Have a friend pull the handle while you observe the latch -- you should see physical movement at the latch where the cable connects. If you don't, the cable may be stretched or broken.
Old Oct 14, 2009 | 05:50 PM
PdPuNOme's Avatar
the only cable there is runs to the keylock on the hatch door itself and there are two wireharnesses that plug into the lock actuator. i got another one out of the junkyard and no luck same thing.
Old Oct 17, 2009 | 06:55 AM
PdPuNOme's Avatar
Ok well i finally got a keyless remote and the trunk button on it pops the hatch so now i know it is not the actuator but has to be the lever so if anyone knows what is down there at the lever that would be great before i go and remove the seat to get to it.
dandyisme
Jun 15, 2025 08:41 AM
mstellar
Jun 12, 2015 02:21 PM
tnvikesfan
Nov 20, 2014 09:41 AM
juggalo2929
Feb 25, 2007 04:32 PM
reevesjo
Dec 8, 2006 12:15 AM
